Shop the Holiday Gift Guide
SodaStream Source External Disassembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
5
Past 30 Days:
22
All Time:
632
Comments: 25
25 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. SodaStream Source External Disassembly, SodaStream Source External Disassembly: step 1, image 1 of 3 SodaStream Source External Disassembly, SodaStream Source External Disassembly: step 1, image 2 of 3 SodaStream Source External Disassembly, SodaStream Source External Disassembly: step 1, image 3 of 3
      • Remove the soda bottle and the COâ‚‚ canister from the machine.
      Ask FixBot
    2. SodaStream Source External Disassembly: step 2, image 1 of 2 SodaStream Source External Disassembly: step 2, image 2 of 2
      Tool used on this step:
      Phillips #1 Screwdriver
      $8.99
      Buy
      Ask FixBot
    3. SodaStream Source External Disassembly: step 3, image 1 of 2 SodaStream Source External Disassembly: step 3, image 2 of 2
      • Pull the outer cover away from the front of the device.
      Ask FixBot
    4. SodaStream Source External Disassembly: step 4, image 1 of 1
      $8.99
      Buy
      Ask FixBot
    5. SodaStream Source External Disassembly: step 5, image 1 of 2 SodaStream Source External Disassembly: step 5, image 2 of 2
      Jimmy
      $7.95
      Buy
      • Firmly pull the front cover off.
      • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
      Ask FixBot
2 other people completed this guide.
Author
with
Hailey Smith
1,606 Reputation
2 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2017 Member of USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 22
All Time: 632
