SodaStream Source Battery Replacement
  1. SodaStream Source Battery Replacement, SodaStream Source External Disassembly: step 1, image 1 of 3 SodaStream Source Battery Replacement, SodaStream Source External Disassembly: step 1, image 2 of 3 SodaStream Source Battery Replacement, SodaStream Source External Disassembly: step 1, image 3 of 3
    • Remove the soda bottle and the CO₂ canister from the machine.
  2. SodaStream Source Battery Replacement: step 2, image 1 of 2 SodaStream Source Battery Replacement: step 2, image 2 of 2
    Tool used on this step:
    Phillips #1 Screwdriver
    $8.99
    Buy
  3. SodaStream Source Battery Replacement: step 3, image 1 of 2 SodaStream Source Battery Replacement: step 3, image 2 of 2
    • Pull the outer cover away from the front of the device.
  4. SodaStream Source Battery Replacement: step 4, image 1 of 1
    $8.99
    Buy
  5. SodaStream Source Battery Replacement: step 5, image 1 of 2 SodaStream Source Battery Replacement: step 5, image 2 of 2
    Jimmy
    $7.95
    Buy
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
  6. SodaStream Source Battery Replacement, Battery: step 6, image 1 of 2 SodaStream Source Battery Replacement, Battery: step 6, image 2 of 2
    • Remove the old battery and replace it with a new 3V lithium battery.
Alexandra I Curtis
989 Reputation
2 Guides authored
USF Tampa, Team S1-G4, Leahy Spring 2017 Member of USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Members
40 Guides authored
Past 24 Hours: 72
Past 7 Days: 248
Past 30 Days: 1,036
All Time: 88,030
