Snapfon ez One Motherboard Replacement
    1. Snapfon ez One Motherboard Replacement, Remove the battery cover: step 1, image 1 of 1
      • Turn off the phone to prevent data loss.
      • Press and slide the battery out to remove it.
      • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
      Ask FixBot
    2. Snapfon ez One Motherboard Replacement, Remove the battery: step 2, image 1 of 1
      • Pry the battery out with your thumb or the iFixit opening tool.
      • Make sure to properly dispose of the old battery at a recycling center.
      Ask FixBot
    1. Snapfon ez One Motherboard Replacement, Removing the plastic inserts: step 3, image 1 of 2 Snapfon ez One Motherboard Replacement, Removing the plastic inserts: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the four rubber inserts from the screw holes using a pair of tweezers.
      Ask FixBot
    2. Snapfon ez One Motherboard Replacement, Remove the shield screws: step 4, image 1 of 3 Snapfon ez One Motherboard Replacement, Remove the shield screws: step 4, image 2 of 3 Snapfon ez One Motherboard Replacement, Remove the shield screws: step 4, image 3 of 3
      • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
      Ask FixBot
    3. Snapfon ez One Motherboard Replacement, Separate the case: step 5, image 1 of 3 Snapfon ez One Motherboard Replacement, Separate the case: step 5, image 2 of 3 Snapfon ez One Motherboard Replacement, Separate the case: step 5, image 3 of 3
      • Separate the front case from the back case.
      • Remove the metal bumper from the front case’s perimeter.
      Ask FixBot
    4. Snapfon ez One Motherboard Replacement, Remove the volume slider: step 6, image 1 of 1
      • Pry the volume slider button out with tweezers.
      • The volume slider button may fall out during the separation of the front and back cases. This is OK.
      Ask FixBot
    5. Snapfon ez One Motherboard Replacement, Remove the motherboard: step 7, image 1 of 3 Snapfon ez One Motherboard Replacement, Remove the motherboard: step 7, image 2 of 3 Snapfon ez One Motherboard Replacement, Remove the motherboard: step 7, image 3 of 3
      • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
      • The last picture is a view of the back of the circuit board.
      Ask FixBot
John Bender
818 Reputation
8 Guides authored
Clemson, Team 6-5, Benson Spring 2014 Member of Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 537
