Ridgid Circular Saw R3205 Switch Replacement
    1. Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: step 1, image 1 of 3 Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: step 1, image 2 of 3 Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: step 1, image 3 of 3
      • Remove the brush assembly with a flat head screwdriver.
      Ask FixBot
    2. Ridgid Circular Saw R3205 Switch Replacement: step 2, image 1 of 3 Ridgid Circular Saw R3205 Switch Replacement: step 2, image 2 of 3 Ridgid Circular Saw R3205 Switch Replacement: step 2, image 3 of 3
      • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
      Ask FixBot
    3. Ridgid Circular Saw R3205 Switch Replacement: step 3, image 1 of 3 Ridgid Circular Saw R3205 Switch Replacement: step 3, image 2 of 3 Ridgid Circular Saw R3205 Switch Replacement: step 3, image 3 of 3
      • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
      • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
      Ask FixBot
    4. Ridgid Circular Saw R3205 Switch Replacement: step 4, image 1 of 2 Ridgid Circular Saw R3205 Switch Replacement: step 4, image 2 of 2
      • The motor housing assembly can now be removed from the rest of the saw.
      Ask FixBot
    1. Ridgid Circular Saw R3205 Switch Replacement, Switch: step 5, image 1 of 1
      • Remove 5 Torx 20 (#8-16 x 5/8 in.) screws from the outer handle.
      Ask FixBot
    2. Ridgid Circular Saw R3205 Switch Replacement: step 6, image 1 of 3 Ridgid Circular Saw R3205 Switch Replacement: step 6, image 2 of 3 Ridgid Circular Saw R3205 Switch Replacement: step 6, image 3 of 3
      • Remove the outer handle.
      Ask FixBot
    3. Ridgid Circular Saw R3205 Switch Replacement: step 7, image 1 of 1
      • Using a phillips head screwdriver remove the (M4 x 12 mm) screw holding the switch in place.
      Ask FixBot
    4. Ridgid Circular Saw R3205 Switch Replacement: step 8, image 1 of 3 Ridgid Circular Saw R3205 Switch Replacement: step 8, image 2 of 3 Ridgid Circular Saw R3205 Switch Replacement: step 8, image 3 of 3
      • Remove the wires that attach to the power cord.
      Ask FixBot
Joshua Caron
792 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 33
All Time: 1,253
