Smart Soldering Iron Cap Disassembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Smart Soldering Iron Cap Disassembly, Remove the cap screw: step 1, image 1 of 2 Smart Soldering Iron Cap Disassembly, Remove the cap screw: step 1, image 2 of 2
      Tool used on this step:
      Phillips #1 Screwdriver
      $5.49
      Buy
      • Use a Phillips screwdriver to remove the 8.0 mm‑long screw at the bottom of the opening of the soldering iron cap that secures the cap tip and clip spring to the cap.
      • You will need a long-shaft screwdriver to be able to reach the screw inside of the soldering iron cap.
      Ask FixBot
    2. Smart Soldering Iron Cap Disassembly, Remove the cap lid: step 2, image 1 of 3 Smart Soldering Iron Cap Disassembly, Remove the cap lid: step 2, image 2 of 3 Smart Soldering Iron Cap Disassembly, Remove the cap lid: step 2, image 3 of 3
      • Pull upward on the cap tip to remove it from the cap.
      • During reassembly, fit the iron prongs at the top of the cap into the holes at the bottom interior of the cap tip.
      Ask FixBot
    3. Smart Soldering Iron Cap Disassembly, Remove the cap spring clip: step 3, image 1 of 3 Smart Soldering Iron Cap Disassembly, Remove the cap spring clip: step 3, image 2 of 3 Smart Soldering Iron Cap Disassembly, Remove the cap spring clip: step 3, image 3 of 3
      • Pull up from the bottom of the cap spring clip.
      • Pull the ends of the spring clip straight out through the holes in the cap to remove it.
      Ask FixBot
Carsten Frauenheim
171,473 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 191
