Smart Parts Ion Bolt Replacement
    1. Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: step 1, image 1 of 3 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: step 1, image 2 of 3 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: step 1, image 3 of 3
      • Remove the air tank by rotating it counterclockwise.
      • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
      • The pressure gauge will indicate the leftover air in the gun.
      Ask FixBot
    2. Smart Parts Ion Bolt Replacement: step 2, image 1 of 2 Smart Parts Ion Bolt Replacement: step 2, image 2 of 2
      • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
      Ask FixBot
    1. Smart Parts Ion Bolt Replacement, Smart Parts Ion De-Gassing: step 3, image 1 of 1
      • Turn the gun on by pressing the power button until the red light blinks.
      • Turn vision mode off by pressing the power button again.
      • Red light should be flashing in a double blink sequence.
      Ask FixBot
    2. Smart Parts Ion Bolt Replacement: step 4, image 1 of 1
      • Pull the trigger to release the air in the gun.
      • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
      Ask FixBot
    1. Smart Parts Ion Bolt Replacement, Grip: step 5, image 1 of 1
      • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
      Ask FixBot
    2. Smart Parts Ion Bolt Replacement: step 6, image 1 of 1
      • Remove the grip by sliding it towards the front of the gun.
      Ask FixBot
    1. Smart Parts Ion Bolt Replacement, Battery: step 7, image 1 of 2 Smart Parts Ion Bolt Replacement, Battery: step 7, image 2 of 2
      • Remove the 9V battery by unsnapping it.
      Ask FixBot
    1. Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: step 8, image 1 of 3 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: step 8, image 2 of 3 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: step 8, image 3 of 3
      • Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
      Ask FixBot
    2. Smart Parts Ion Bolt Replacement: step 9, image 1 of 2 Smart Parts Ion Bolt Replacement: step 9, image 2 of 2
      • Remove the 12 mm screw on the top of the grip frame using a 3/32" Allen wrench.
      Ask FixBot
    3. Smart Parts Ion Bolt Replacement: step 10, image 1 of 1
      • Separate the gun's body from the frame by gently pulling them in opposite directions.
      Ask FixBot
    4. Smart Parts Ion Bolt Replacement: step 11, image 1 of 1
      • Remove the 1-1/4" screw that's attached to the blue tube above the front grip using a 3/32" Allen Wrench.
      Ask FixBot
    1. Smart Parts Ion Bolt Replacement, Removing the Solenoid from the Body: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
      • Another small tool or your fingers will work for this.
      Ask FixBot
    2. Smart Parts Ion Bolt Replacement: step 13, image 1 of 1
      • Remove the two 1-1/4" screws on either side of the circuit board using a 3/32" allen wrench.
      Ask FixBot
    3. Smart Parts Ion Bolt Replacement: step 14, image 1 of 1
      • Separate the solenoid from the gun's body by gently pulling it upwards.
      Ask FixBot
    4. Smart Parts Ion Bolt Replacement: step 15, image 1 of 1
      • Slide the metal body out of the plastic shell by holding one in each hand and gently pulling apart.
      Ask FixBot
    1. Smart Parts Ion Bolt Replacement, Bolt: step 16, image 1 of 2 Smart Parts Ion Bolt Replacement, Bolt: step 16, image 2 of 2
      • Separate the front body breach from the fire chamber by rotating the breach counterclockwise.
      Ask FixBot
    2. Smart Parts Ion Bolt Replacement: step 17, image 1 of 1
      • Remove the bolt from the front body breach by gently pulling on the bolt.
      Ask FixBot
3 other people completed this guide.
Shane Villalpando
1,043 Reputation
10 Guides authored
Cal Poly, Team 8-42, Amido Winter 2015 Member of Cal Poly, Team 8-42, Amido Winter 2015
CPSU-AMIDO-W15S8G42
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 76
All Time: 3,364
