Shop the Holiday Gift Guide
Skullcandy Air Raid Back Panel Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
8
All Time:
245
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Skullcandy Air Raid Back Panel Replacement, Rubber Cover: step 1, image 1 of 1
      • Starting with the corners, gently pull the rubber cover off of the device.
      Ask FixBot
    2. Skullcandy Air Raid Back Panel Replacement, Handle: step 2, image 1 of 1
      • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
      • Remove the handle from the device.
      Ask FixBot
    3. Skullcandy Air Raid Back Panel Replacement, Front Plate: step 3, image 1 of 1
      • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
      • One 5mm Phillips screw.
      • One 8mm Phillips screw.
      Ask FixBot
    4. Skullcandy Air Raid Back Panel Replacement: step 4, image 1 of 1
      • Gently pull the sides of the front plate outwards from the device.
      • Pull up on the front plate to remove it from the device.
      Ask FixBot
    1. Skullcandy Air Raid Back Panel Replacement, Speakers: step 5, image 1 of 1
      • Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
      Ask FixBot
    2. Skullcandy Air Raid Back Panel Replacement: step 6, image 1 of 1
      • Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
      • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
      Ask FixBot
    3. Skullcandy Air Raid Back Panel Replacement: step 7, image 1 of 1
      • Lift the speaker out of the device.
      • Be aware of the connection with the ribbon cable.
      • For reassembly, ensure proper orientation of the cable plug.
      Ask FixBot
    4. Skullcandy Air Raid Back Panel Replacement: step 8, image 1 of 1
      • Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
      Ask FixBot
    5. Skullcandy Air Raid Back Panel Replacement, Control Buttons: step 9, image 1 of 1
      • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
      Ask FixBot
    6. Skullcandy Air Raid Back Panel Replacement: step 10, image 1 of 1
      • Lift the button panel.
      Ask FixBot
    7. Skullcandy Air Raid Back Panel Replacement, Button Motherboard: step 11, image 1 of 1
      • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
      Ask FixBot
    8. Skullcandy Air Raid Back Panel Replacement: step 12, image 1 of 1
      • Using a plastic opening tool, pry the button motherboard to detach it from the device.
      • The button motherboard is connected to a ribbon cable inside the device.
      Ask FixBot
    9. Skullcandy Air Raid Back Panel Replacement, Ribbon Cable: step 13, image 1 of 1
      • Pull the black ribbon cord attachment away from the motherboard.
      • Pull on the cable until it releases from the back of the motherboard.
      • The black attachment is part of the connector, not the blue ribbon cable, so it will not disconnect from the motherboard.
      Ask FixBot
    10. Skullcandy Air Raid Back Panel Replacement, Back panel: step 14, image 1 of 2 Skullcandy Air Raid Back Panel Replacement, Back panel: step 14, image 2 of 2
      • Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
      • Lift off the back panel.
      Ask FixBot
Author
with
Kristin
495 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 245
