Skil 88 Motor Replacement
  1. Skil 88 Motor Replacement, Disassembling Skil 88 Front Housing: step 1, image 1 of 1
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Skil 88 Motor Replacement: step 2, image 1 of 2 Skil 88 Motor Replacement: step 2, image 2 of 2
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
  3. Skil 88 Motor Replacement, Motor: step 3, image 1 of 2 Skil 88 Motor Replacement, Motor: step 3, image 2 of 2
    • Remove the gear that is threaded onto the divider.
  4. Skil 88 Motor Replacement: step 4, image 1 of 2 Skil 88 Motor Replacement: step 4, image 2 of 2
    • Remove the divider from the rear housing.
    • The motor may come out along with the divider.
  5. Skil 88 Motor Replacement: step 5, image 1 of 2 Skil 88 Motor Replacement: step 5, image 2 of 2
    • Pull out the motor.
  6. Skil 88 Motor Replacement: step 6, image 1 of 3 Skil 88 Motor Replacement: step 6, image 2 of 3 Skil 88 Motor Replacement: step 6, image 3 of 3
    • For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it.
    • Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed.
    • Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
Matt
365 Reputation
7 Guides authored
Cal Poly, Team 5-17, Maness Fall 2010 Member of Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 17
All Time: 650
