Introduction
The dispenser drawer, also called the detergent drawer or dispensing drawer, carries detergent and fabric conditioner into the wash. Over time, washing powder, conditioner residue, and grime can build up in the drawer and drawer cavity, which can wash back onto clothes. Use this guide to remove, clean, and refit the dispenser drawer on a Siemens washing machine, with the Siemens VarioPerfect model used as the reference. Clean the drawer about every six months to keep the machine hygienic and working well.
Step 1 Prepare the washing machine
Wear rubber gloves if detergent residue irritates your skin or the drawer is very dirty.
Step 2 Remove the dispenser drawer
Place a hand under the dispenser drawer and pull it straight out until it stops.
Press down on the blue release button inside the drawer.
Hold the blue release button down and pull the dispenser drawer fully out of the washing machine.
Step 3 Clean the dispenser drawer
Rinse loose residue out of the dispenser drawer with hot, soapy water.
Use an brush to scrub the detergent and conditioner compartments until the residue is gone.
Pay extra attention to corners and areas with thick washing powder or conditioner buildup.
Rinse away loosened soap and grime before refitting the drawer.
Step 4 Clean the drawer cavity
Use a cloth to wipe inside the dispenser drawer cavity while the drawer is removed.
Remove visible detergent powder, conditioner sludge, and grime from the drawer opening.
Step 5 Refit the dispenser drawer
Press the blue release button down on the dispenser drawer.
Line up the drawer with the grooves in the dispenser opening.
Push the drawer all the way in until it sits flush.
Step 6 Inspect the drum rubber
Open the washing machine door and inspect the rubber door seal around the drum.
Check that the drainage holes in the rubber seal are clear.
Use a cloth and hot, soapy water to wipe dirt, lint, and residue from the rubber seal.
Step 7 Run a maintenance wash
Close the door and the dispenser drawer.
Plug in the washing machine.
Select a 90 °C wash program, the hottest wash available, or the Drum Clean option if the machine has one.
Run the wash with no clothes in the drum to flush residue from the machine.
Repeat this cleaning about every six months, or sooner if you see detergent buildup, conditioner sludge, or grime around the drawer or drum seal. Repair didn't go as planned? Ask our Answers community for help.
