Repairing Sidekick II Outer Casing
  1. Repairing Sidekick II Outer Casing, Outer Casing: step 1, image 1 of 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Repairing Sidekick II Outer Casing: step 2, image 1 of 2 Repairing Sidekick II Outer Casing: step 2, image 2 of 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Repairing Sidekick II Outer Casing: step 3, image 1 of 1
    • Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Repairing Sidekick II Outer Casing: step 4, image 1 of 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Repairing Sidekick II Outer Casing: step 5, image 1 of 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
michael albaum
87 Reputation
6 Guides authored
Cal Poly, Team 3-19, Maness Winter 2010 Member of Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Members
11 Guides authored
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 17
All Time: 2,396
