Side Panel Removal
  1. Side Panel Removal, Side Panel Removal: step 1, image 1 of 3 Side Panel Removal, Side Panel Removal: step 1, image 2 of 3 Side Panel Removal, Side Panel Removal: step 1, image 3 of 3
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
  2. Side Panel Removal: step 2, image 1 of 3 Side Panel Removal: step 2, image 2 of 3 Side Panel Removal: step 2, image 3 of 3
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
7 other people completed this guide.
Oli
1,550 Reputation
4 Guides authored
1 Guide Comment
I took it out, but now it’s not going all the way in
Ali - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 103
All Time: 3,281
