Shortening a Child’s Princess Dress Without Cutting It
  1. Shortening a Child’s Princess Dress Without Cutting It, Shortening a Child’s Princess Dress Without Cutting It: step 1, image 1 of 3 Shortening a Child’s Princess Dress Without Cutting It, Shortening a Child’s Princess Dress Without Cutting It: step 1, image 2 of 3 Shortening a Child’s Princess Dress Without Cutting It, Shortening a Child’s Princess Dress Without Cutting It: step 1, image 3 of 3
    • Have the child put on the too-long dress.
    • Fold the fabric inwards to the desired length.
    • If the dress has multiple layers, you'll have to repeat this entire procedure for each layer.
  2. Shortening a Child’s Princess Dress Without Cutting It: step 2, image 1 of 2 Shortening a Child’s Princess Dress Without Cutting It: step 2, image 2 of 2
    • To secure the fabric, place a sewing pin longways into the folded fabric.
    • You should repeat this step with any fabric you want to shorten.
    • Remember, you need to pin one fabric at a time to avoid sewing the layers of fabrics to each other.
    • You need to carefully remove the dress from the child, inserting your hand between the child and the sewing needles when removing so you don't poke the child.
  3. Shortening a Child’s Princess Dress Without Cutting It: step 3, image 1 of 3 Shortening a Child’s Princess Dress Without Cutting It: step 3, image 2 of 3 Shortening a Child’s Princess Dress Without Cutting It: step 3, image 3 of 3
    • Lay the dress flat on a neat, stable surface like a table.
    • Fold each fabric layer to identical lengths.
    • After it's the same length, you need to insert sewing pins in the middle or at the edge of the folded fabric, like in the previous step.
  4. Shortening a Child’s Princess Dress Without Cutting It: step 4, image 1 of 2 Shortening a Child’s Princess Dress Without Cutting It: step 4, image 2 of 2
    • For the next side (red arrow), fold it inwards to match the length of the original pinned fabric (orange arrow).
    • Insert sewing pins like in Steps 2 and 3.
  5. Shortening a Child’s Princess Dress Without Cutting It: step 5, image 1 of 2 Shortening a Child’s Princess Dress Without Cutting It: step 5, image 2 of 2
    • Grab a sewing needle and a thread that matches the color of your fabric.
    • Measure the thread to be the same length as the original pinned fabric, then cut the thread.
    • Insert one end of the thread into the eye of the needle.
    • Leave some length at the top for the next step.
  6. Shortening a Child’s Princess Dress Without Cutting It: step 6, image 1 of 3 Shortening a Child’s Princess Dress Without Cutting It: step 6, image 2 of 3 Shortening a Child’s Princess Dress Without Cutting It: step 6, image 3 of 3
    • Thread the needle and knot the thread.
  7. Shortening a Child’s Princess Dress Without Cutting It: step 7, image 1 of 3 Shortening a Child’s Princess Dress Without Cutting It: step 7, image 2 of 3 Shortening a Child’s Princess Dress Without Cutting It: step 7, image 3 of 3
    • Insert the needle into the fabric following this motion: down, up, down, up, slight pull out. This creates a circle with the thread.
    • Before the circle ends, you need to pass the needle through the circle, then down into the fabric.
    • You need to pull the thread and needle through all the way.
    • By doing this, you prevent the thread from loosening.
  8. Shortening a Child’s Princess Dress Without Cutting It: step 8, image 1 of 3 Shortening a Child’s Princess Dress Without Cutting It: step 8, image 2 of 3 Shortening a Child’s Princess Dress Without Cutting It: step 8, image 3 of 3
    • Next, you take the needle, insert into the fabric half way then go up, and pull the needle and thread through a little bit.
    • Remember to pull gently so the thread doesn't get knotted.
    • You need to repeat until two-thirds of thread is left or until you get to the start again.
  9. Shortening a Child’s Princess Dress Without Cutting It: step 9, image 1 of 1
    • When there is 2/3 of thread left in the needle, repeat Step 8.
    • After securing it, you need to cut the thread from the needle, closest to where the needle is.
    • You need to remove all of the sewing pins from the fabric you have sowed.
    • For the rest of the fabric or other fabrics, you need to repeat Steps 6-10.
  10. Shortening a Child’s Princess Dress Without Cutting It: step 10, image 1 of 1
    • After you removed the sewing pins, you are finished!
    • Caution: If you leave the sewing pins on the dress, it will hurt the child who wears it.
Mariana L
181 Reputation
1 Guide authored
CSU Sacramento, Team 1-12, Laflen Fall 2024 Member of CSU Sacramento, Team 1-12, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G12
1 Member
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 226
