Up to 20% off select tools
Shoe Insole Repair
Views: 1.7K
View statistics:
Past 24 Hours:
11
Past 7 Days:
100
Past 30 Days:
393
All Time:
1,680
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Easy
Shoe Insole Repair
Introduction
Go to step 1 ↓
Shoe insoles often develop holes or thin worn spots from regular use, which can make walking uncomfortable and allow debris to get inside your shoe. This easy repair lets you patch the damaged area using scrap foam or fabric you likely already have at home, saving you from buying new insoles or shoes.
No special skills or tools are required beyond basic household items. The repair takes about 10–15 minutes of active work plus drying time (total around 30–60 minutes depending on your glue).
Note: Work in a well-ventilated area when using glue. If your insole is extremely thin, crumbling, or the damage is very extensive, replacing the entire insole (or the shoes) may be a better long-term solution.
    1. Shoe Insole Repair, Shoe Insole Repair: step 1, image 1 of 1
      • Collect everything you need for the repair.
      • A piece of foam from new shoe packaging is ideal because it matches the insole’s cushioning. If you don’t have foam, a thick old sock or piece of soft clothing works well too.
      Ask FixBot
    2. Shoe Insole Repair: step 2, image 1 of 2 Shoe Insole Repair: step 2, image 2 of 2
      • Place your insole on a flat surface. Use a marker or pen to trace the outline of the hole (or worn spot) onto your scrap foam or fabric.
      • Trace slightly larger than the hole so the patch overlaps the edges a little for a stronger repair.
      Ask FixBot
    3. Shoe Insole Repair: step 3, image 1 of 3 Shoe Insole Repair: step 3, image 2 of 3 Shoe Insole Repair: step 3, image 3 of 3
      • Carefully cut along your traced line with scissors. Test the patch in the hole; it should sit flush or slightly above the insole. Trim as needed until it fits snugly without gaps.
      • If the hole goes all the way through the insole, cut a second identical patch to layer underneath for extra support.
      Ask FixBot
    4. Shoe Insole Repair: step 4, image 1 of 3 Shoe Insole Repair: step 4, image 2 of 3 Shoe Insole Repair: step 4, image 3 of 3
      • Apply a thin layer of glue all around the edges of the patch. Press it firmly into the hole so the glue makes good contact with the surrounding insole. Use small pieces of tape to hold the patch securely while the glue dries.
      • Usually 10–30 minutes, or follow your glue’s drying instructions).
      Ask FixBot
    5. Shoe Insole Repair: step 5, image 1 of 2 Shoe Insole Repair: step 5, image 2 of 2
      • Once the glue is fully dry, remove the tape. Press on the patch and test how it feels.
      • If it’s loose or there are gaps, apply a bit more glue around the edges and tape it down again to dry.
      Ask FixBot
    6. Shoe Insole Repair: step 6, image 1 of 1
      • This step is optional. For a longer-lasting and more comfortable repair, cut a thin piece of fabric (from an old sock or t-shirt) slightly larger than the patch. Apply glue to the back of the fabric and press it smoothly over the repaired area. This creates a softer surface for your foot and helps the patch hold up better over time.
      Ask FixBot
Finish Line
Author
with
Claire Vest
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 100
Past 30 Days: 393
All Time: 1,680
