Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓This guide shows how to remove the shifter assembly from the Logitech RS Shifter & Handbrake.
Tools
Unplug the shifter's USB cable.
Completely unmount the shifter from the clamp and remove any accessories so you're left with just the shifter.
Use a 4.0 mm hex screwdriver to remove the 31 mm‑long screws securing the shifter to the clamp.
Use a 2.5 mm hex screwdriver to remove the four 11 mm‑long screws securing the top cover.
Remove the eight screws securing the chassis:
Four 10 mm‑long 2.5 mm hex screws
Four 12 mm‑long Phillips screws
Use a long-shank Phillips screwdriver to remove the six 12 mm‑long screws securing the midframe.
Use your fingers to grip the switch cable's white connector and pull it straight up and out of the socket.
Use a 3 mm ball-end hex key to remove the four 14 mm‑long screws securing the shifter assembly.
