Introduction
This guide will show you how to replace the white outer shell of the speaker system. Minimal disassembly is needed.
Gently position the device so that the buttons and speakers lie face down.
Unplug the power cord from the "DC Input."
Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
Lay the device down, so that all the internal components are facing upwards.
