Sharper Image SVC430 Disassembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Sharper Image SVC430 Disassembly, Sharper Image SVC430 Disassembly: step 1, image 1 of 2 Sharper Image SVC430 Disassembly, Sharper Image SVC430 Disassembly: step 1, image 2 of 2
      • Power off your device before you begin.
      • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
      Ask FixBot
    2. Sharper Image SVC430 Disassembly: step 2, image 1 of 2 Sharper Image SVC430 Disassembly: step 2, image 2 of 2
      • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
      Ask FixBot
    3. Sharper Image SVC430 Disassembly: step 3, image 1 of 3 Sharper Image SVC430 Disassembly: step 3, image 2 of 3 Sharper Image SVC430 Disassembly: step 3, image 3 of 3
      • Locate the bottom of the device.
      • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
      Ask FixBot
    4. Sharper Image SVC430 Disassembly: step 4, image 1 of 2 Sharper Image SVC430 Disassembly: step 4, image 2 of 2
      • This panel should come off easily, do not apply too much pressure.
      • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
      • Locate the two screws on the top of the device.
      Ask FixBot
    5. Sharper Image SVC430 Disassembly: step 5, image 1 of 1
      • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
      Ask FixBot
    6. Sharper Image SVC430 Disassembly: step 6, image 1 of 3 Sharper Image SVC430 Disassembly: step 6, image 2 of 3 Sharper Image SVC430 Disassembly: step 6, image 3 of 3
      • Use the plastic opening tool to pry off the back panel.
      • The back panel will come off easily.
      Ask FixBot
    7. Sharper Image SVC430 Disassembly: step 7, image 1 of 1
      • Use the metal screwdriver to unscrew the screw from the back of the device.
      Ask FixBot
    8. Sharper Image SVC430 Disassembly: step 8, image 1 of 1
      • Use the plastic opening tool to pry off the front panel of the device.
      Ask FixBot
    9. Sharper Image SVC430 Disassembly: step 9, image 1 of 1
      • Using the screwdriver, unscrew the screw located underneath the front panel.
      Ask FixBot
    10. Sharper Image SVC430 Disassembly: step 10, image 1 of 1
      • Be gentle with the device since there are wires attached to the front plate and two halves.
      • Gently pull both sides of the device to expose the interior of the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 292
