Sharp EL-W535XG Battery Replacement
    1. Sharp EL-W535XG Battery Replacement, Battery: step 1, image 1 of 2 Sharp EL-W535XG Battery Replacement, Battery: step 1, image 2 of 2
      • Turn off the calculator by pressing both the [2NDF ] and [ON] buttons at the same time.
      Ask FixBot
    2. Sharp EL-W535XG Battery Replacement: step 2, image 1 of 1
      • Flip the calculator so that the battery cover is facing you, and it will be easy to remove.
      Ask FixBot
    3. Sharp EL-W535XG Battery Replacement: step 3, image 1 of 2 Sharp EL-W535XG Battery Replacement: step 3, image 2 of 2
      • Remove the two screws securing the battery cover with the Tri-point #000 screwdriver.
      • Remove the battery cover.
      • Make sure not to remove the other screws on the calculator, just the two screws on the battery cover.
      Ask FixBot
    4. Sharp EL-W535XG Battery Replacement: step 4, image 1 of 2 Sharp EL-W535XG Battery Replacement: step 4, image 2 of 2
      • Remove the worn-out LR44 battery inside using a spudger.
      Ask FixBot
    5. Sharp EL-W535XG Battery Replacement: step 5, image 1 of 1
      • Gently insert the new LR44 battery in the empty battery slot.
      Ask FixBot
    6. Sharp EL-W535XG Battery Replacement: step 6, image 1 of 1
      • Place and screw the battery cover on using the Tri-point #000 screwdriver.
      • Tightly screw the battery cover to prevent losing screws.
      Ask FixBot
Faduma Hagi
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 40
All Time: 2,629
