Replacing Sharp Aquos LC13B2UA LCD
  1. Replacing Sharp Aquos LC13B2UA LCD, Stand: step 1, image 1 of 2 Replacing Sharp Aquos LC13B2UA LCD, Stand: step 1, image 2 of 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Replacing Sharp Aquos LC13B2UA LCD: step 2, image 1 of 2 Replacing Sharp Aquos LC13B2UA LCD: step 2, image 2 of 2
    • Lift the stand off the television.
  3. Replacing Sharp Aquos LC13B2UA LCD, Back Case: step 3, image 1 of 3 Replacing Sharp Aquos LC13B2UA LCD, Back Case: step 3, image 2 of 3 Replacing Sharp Aquos LC13B2UA LCD, Back Case: step 3, image 3 of 3
    • Remove the two back panels by prying them out with your hands.
  4. Replacing Sharp Aquos LC13B2UA LCD: step 4, image 1 of 2 Replacing Sharp Aquos LC13B2UA LCD: step 4, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Replacing Sharp Aquos LC13B2UA LCD: step 5, image 1 of 1
    • Using your hands, gently lift and remove the back case of the television.
  6. Replacing Sharp Aquos LC13B2UA LCD, Motherboard: step 6, image 1 of 3 Replacing Sharp Aquos LC13B2UA LCD, Motherboard: step 6, image 2 of 3 Replacing Sharp Aquos LC13B2UA LCD, Motherboard: step 6, image 3 of 3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Replacing Sharp Aquos LC13B2UA LCD: step 7, image 1 of 2 Replacing Sharp Aquos LC13B2UA LCD: step 7, image 2 of 2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Replacing Sharp Aquos LC13B2UA LCD: step 8, image 1 of 2 Replacing Sharp Aquos LC13B2UA LCD: step 8, image 2 of 2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Replacing Sharp Aquos LC13B2UA LCD: step 9, image 1 of 1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Replacing Sharp Aquos LC13B2UA LCD, LCD: step 10, image 1 of 1
    • Flip the LCD/circuit board so that the circuit board faces up.
  11. Replacing Sharp Aquos LC13B2UA LCD: step 11, image 1 of 3 Replacing Sharp Aquos LC13B2UA LCD: step 11, image 2 of 3 Replacing Sharp Aquos LC13B2UA LCD: step 11, image 3 of 3
    • Remove the three 5mm Philips screws attaching the circuit board to the LCD.
    • Remove the five 6mm Phillips screws from the edges of the circuit board attacking it to the LCD.
  12. Replacing Sharp Aquos LC13B2UA LCD: step 12, image 1 of 3 Replacing Sharp Aquos LC13B2UA LCD: step 12, image 2 of 3 Replacing Sharp Aquos LC13B2UA LCD: step 12, image 3 of 3
    • Turn the circuit board so the blue and pink side cables are facing you.
    • Hold the white plastic, squeeze and pull from the sides.
  13. Replacing Sharp Aquos LC13B2UA LCD: step 13, image 1 of 3 Replacing Sharp Aquos LC13B2UA LCD: step 13, image 2 of 3 Replacing Sharp Aquos LC13B2UA LCD: step 13, image 3 of 3
    • Turn the television so the right hand side is facing you.
    • To remove the ribbon cables, fold the brown casing down and pull directly upward on the ribbon.
    • Turn the television so the left hand side is facing you, and remove the ribbon cable in the same manner.
  14. Replacing Sharp Aquos LC13B2UA LCD: step 14, image 1 of 3 Replacing Sharp Aquos LC13B2UA LCD: step 14, image 2 of 3 Replacing Sharp Aquos LC13B2UA LCD: step 14, image 3 of 3
    • Turn the circuit board so that the left side is facing you.
    • Detach the data cable from the circuit board.
    • To do this, slide your finger nail from the middle of the connector until the little black tabs rotates down toward the board as shown in the second picture.
  15. Replacing Sharp Aquos LC13B2UA LCD: step 15, image 1 of 1
    • Lift and remove the circuit board from the LCD frame.
  16. Replacing Sharp Aquos LC13B2UA LCD: step 16, image 1 of 1
    • Now you have your LCD.
Robert Hobson
1,290 Reputation
9 Guides authored
Cal Poly, Team 1-11, Amido Winter 2011 Member of Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 8,391
