Replacing Sharp Aquos LC13B2UA Fuses
  1. Replacing Sharp Aquos LC13B2UA Fuses, Stand: step 1, image 1 of 2 Replacing Sharp Aquos LC13B2UA Fuses, Stand: step 1, image 2 of 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Replacing Sharp Aquos LC13B2UA Fuses: step 2, image 1 of 2 Replacing Sharp Aquos LC13B2UA Fuses: step 2, image 2 of 2
    • Lift the stand off the television.
  3. Replacing Sharp Aquos LC13B2UA Fuses, Back Case: step 3, image 1 of 3 Replacing Sharp Aquos LC13B2UA Fuses, Back Case: step 3, image 2 of 3 Replacing Sharp Aquos LC13B2UA Fuses, Back Case: step 3, image 3 of 3
    • Remove the two back panels by prying them out with your hands.
  4. Replacing Sharp Aquos LC13B2UA Fuses: step 4, image 1 of 2 Replacing Sharp Aquos LC13B2UA Fuses: step 4, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Replacing Sharp Aquos LC13B2UA Fuses: step 5, image 1 of 1
    • Using your hands, gently lift and remove the back case of the television.
  6. Replacing Sharp Aquos LC13B2UA Fuses, Fuses: step 6, image 1 of 2 Replacing Sharp Aquos LC13B2UA Fuses, Fuses: step 6, image 2 of 2
    • To identify a broken fuse, look at the thin wire running through the center of the fuse. If the wire is misshapen or broken, the fuse needs to be replaced.
    • To remove the fuse, either push from one side or pry gently with a spudger.
    • Make sure to replace the fuse with the correct amperage and voltage fuse. The correct voltage and amperage is displayed on the side of the fuse.
Robert Hobson
1,290 Reputation
9 Guides authored
Cal Poly, Team 1-11, Amido Winter 2011 Member of Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Members
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 11,772
