Sharp Aquos LC13B2UA Back Case Replacement
  1. Sharp Aquos LC13B2UA Back Case Replacement, Stand: step 1, image 1 of 2 Sharp Aquos LC13B2UA Back Case Replacement, Stand: step 1, image 2 of 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Back Case Replacement: step 2, image 1 of 2 Sharp Aquos LC13B2UA Back Case Replacement: step 2, image 2 of 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Back Case Replacement, Back Case: step 3, image 1 of 3 Sharp Aquos LC13B2UA Back Case Replacement, Back Case: step 3, image 2 of 3 Sharp Aquos LC13B2UA Back Case Replacement, Back Case: step 3, image 3 of 3
    • Remove the two back panels.
  4. Sharp Aquos LC13B2UA Back Case Replacement: step 4, image 1 of 2 Sharp Aquos LC13B2UA Back Case Replacement: step 4, image 2 of 2
    • Remove the eight 6mm Phillips screws around the edge.
    • Remove the two 6mm Phillips screws near the inputs.
  5. Sharp Aquos LC13B2UA Back Case Replacement: step 5, image 1 of 1
    • Lift and remove the back case of the television.
Robert Hobson
1,290 Reputation
9 Guides authored
Cal Poly, Team 1-11, Amido Winter 2011 Member of Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 4,133
