Introduction
The vacuum belt keeps the brushroll spinning properly. If your brushroll is not spinning or is spinning irregularly, you may need to check the placement and/or quality of the belt. This guide will show you how to access and remove the belt.
Locate the release button at the top of the vacuum pod next to the handle.
Use the handle to lift the pod up off of the vacuum nozzle while pressing the release button.
Press the Brushroll Access buttons on the top of the nozzle to reveal the brushroll compartment.
Remove the panel to reveal the motor screw.
Remove the 7.5mm Torx #20 motor screw.
Remove the motor.
