Shop the Holiday Gift Guide
Shark Rocket HV381 LED Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
112
All Time:
1,093
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a step by step guide to replacing busted LED lights on the Shark Rocket HV381.
Tools
    1. Shark Rocket HV381 LED Replacement, Roller: step 1, image 1 of 2 Shark Rocket HV381 LED Replacement, Roller: step 1, image 2 of 2
      • On the right-bottom of the body, pull down the black switch. You will hear an audible click when you detach the body from the vacuum head.
      Ask FixBot
    2. Shark Rocket HV381 LED Replacement: step 2, image 1 of 1
      • Laying the vacuum head on the its right side, push the orange "Eject Roller" switch down. The Roller can now be removed with ease.
      Ask FixBot
    1. Shark Rocket HV381 LED Replacement, LED: step 3, image 1 of 2 Shark Rocket HV381 LED Replacement, LED: step 3, image 2 of 2
      • On the back of the vacuum head, located near the bottom, should be a row of screws. Using the T15 Screwdriver, remove all the screws on the bottom and the sides.
      Ask FixBot
    2. Shark Rocket HV381 LED Replacement: step 4, image 1 of 1
      • On the top side of the vacuum head, where the LED is located, use the Small Flathead screwdriver to pry open the cover. There should be no resistance.
      Ask FixBot
    3. Shark Rocket HV381 LED Replacement: step 5, image 1 of 3 Shark Rocket HV381 LED Replacement: step 5, image 2 of 3 Shark Rocket HV381 LED Replacement: step 5, image 3 of 3
      • Picking the LED from the side, pull upwards to unwind the wires from their tracks.
      • Make sure that you are gentle because the wires are very fragile. One strong pull could easily snap them from the LED.
      Ask FixBot
Author
with
Dandre Porter
528 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 112
All Time: 1,093
