Shark Pet Perfect II Battery Replacement
    1. Shark Pet Perfect II Battery Replacement, Battery: step 1, image 1 of 3 Shark Pet Perfect II Battery Replacement, Battery: step 1, image 2 of 3 Shark Pet Perfect II Battery Replacement, Battery: step 1, image 3 of 3
      • Locate and remove the 7.5mm Philips screw holding the battery cover in place on bottom of the vacuum.
      Ask FixBot
    2. Shark Pet Perfect II Battery Replacement: step 2, image 1 of 3 Shark Pet Perfect II Battery Replacement: step 2, image 2 of 3 Shark Pet Perfect II Battery Replacement: step 2, image 3 of 3
      • Once the cover is removed, slide the plastic retaining bracket down and pull out to remove.
      Ask FixBot
    3. Shark Pet Perfect II Battery Replacement: step 3, image 1 of 3 Shark Pet Perfect II Battery Replacement: step 3, image 2 of 3 Shark Pet Perfect II Battery Replacement: step 3, image 3 of 3
      • Pull the battery out of the compartment.
      • Carefully disconnect the quick disconnect couplers.
      • The Couplers may be tightly secured so it may be necessary to use a small flat device to carefully loosen the coupler.
      • Be sure to use an ESD safe tool like the nylon spudger when working with wires and batteries—this will prevent injury and/or device damage.
      Ask FixBot
    4. Shark Pet Perfect II Battery Replacement: step 4, image 1 of 1
      • Completely remove the old battery from the vacuum .
      Ask FixBot
4 other people completed this guide.
Attached Documents
Christine Robles
113 Reputation
1 Guide authored
UW Tacoma, Team S1-G5, Liner Summer 2017 Member of UW Tacoma, Team S1-G5, Liner Summer 2017
UWT-LINER-SU17S1G5
4 Members
32 Guides authored
12 Guide Comments
Removed the single screw but cover will not come off. What do you do?
Adalyn Etelamaki - Reply Share
Just tried it. The cover is a bit hard. Gold the vacuum at an angle and slightly push the notch on the cover with a flat screwdriver, it should come out.
PradSim Promo Ads - Reply Share
Will it run on cord only
ligthelf - Reply Share
NO. Requires batteries.
Jim DeCamp - Reply Share
1.) Mine was much harder to disassemble, took considerable force.
2.) No one sells form, fit and function replacement batteries, including Shark
3.) The available replacement are much smaller in volume, and hence power, and require padding or they will rattle.
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 84
All Time: 19,992
