Shark Navigator Lightweight Upright Motor Replacement
  1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: step 1, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement, Head Shell: step 1, image 2 of 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motor Replacement: step 2, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 2, image 2 of 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motor Replacement: step 3, image 1 of 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motor Replacement: step 4, image 1 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 4, image 2 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 4, image 3 of 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motor Replacement: step 5, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 5, image 2 of 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motor Replacement: step 6, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 6, image 2 of 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motor Replacement: step 7, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 7, image 2 of 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motor Replacement: step 8, image 1 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 8, image 2 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 8, image 3 of 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motor Replacement, Motor: step 9, image 1 of 1
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motor Replacement: step 10, image 1 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 10, image 2 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 10, image 3 of 3
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motor Replacement: step 11, image 1 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 11, image 2 of 3 Shark Navigator Lightweight Upright Motor Replacement: step 11, image 3 of 3
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motor Replacement: step 12, image 1 of 2 Shark Navigator Lightweight Upright Motor Replacement: step 12, image 2 of 2
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
Suzie
527 Reputation
4 Guides authored
Cal Poly, Team S4-G6, Livingston Fall 2017 Member of Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Members
12 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 47
All Time: 9,506
