Shark Matrix RV2310 Wheel Assembly Replacement
    1. Shark Matrix RV2310 Wheel Assembly Replacement, Battery: step 1, image 1 of 3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: step 1, image 2 of 3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: step 1, image 3 of 3
      • Remove the two 11 mm Phillips screws holding the battery plate in place.
      • Remove the battery plate.
      Ask FixBot
    2. Shark Matrix RV2310 Wheel Assembly Replacement: step 2, image 1 of 3 Shark Matrix RV2310 Wheel Assembly Replacement: step 2, image 2 of 3 Shark Matrix RV2310 Wheel Assembly Replacement: step 2, image 3 of 3
      • Remove the battery from the compartment.
      • Disconnect the electrical cable connection from the battery to the robot.
      Ask FixBot
    1. Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: step 3, image 1 of 2 Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: step 3, image 2 of 2
      • Remove the five 11 mm Phillips screws holding the wheel assembly in place.
      • Make sure the device's battery has been fully removed from the device before proceeding. Failure to do so could potentially result in minor/moderate injuries.
      Ask FixBot
    2. Shark Matrix RV2310 Wheel Assembly Replacement: step 4, image 1 of 1
      • Lift the wheel assembly out of the vacuum.
      • Do not pull or tug too hard on the wheel when lifting it, as there is a wire connection between the wheel and the motherboard.
      Ask FixBot
    3. Shark Matrix RV2310 Wheel Assembly Replacement: step 5, image 1 of 1
      • Undo the wire connection between the motherboard and the wheel assembly by gently pulling the wire out from the wheel assembly's connector.
      Ask FixBot
2 other people completed this guide.
Joshua Correia
715 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 116
All Time: 1,379
