Introduction
If your Shark ION R750 is experiencing low battery life or charging issues, it may be due to battery damage or death, which requires a replacement.
The battery in a robot vacuum serves as the power source for its operation. Damage or malfunction in the battery can occur due to factors such as overcharging, exposure to extreme temperatures, serious crash, or age.
Continuing to operate a damaged battery can be hazardous, possibly leading to a heat reaction between the battery's lithium and oxygen or other dangerous malfunctions.
Before you start the replacement, please be sure to disconnect any power resources from the vacuum and make sure it is completely off.
On the bottom of the vacuum, unscrew both sides of the vacuum cover using a Phillips screwdriver.
Gently lift and remove the cover.
