Shark Flex DuoClean Suction Motor Replacement
  1. Shark Flex DuoClean Suction Motor Replacement, Dust Cup: step 1, image 1 of 2 Shark Flex DuoClean Suction Motor Replacement, Dust Cup: step 1, image 2 of 2
    • Squeeze Dust Cup release buttons on either side of the component.
    • Pull up to release Dust Cup.
  2. Shark Flex DuoClean Suction Motor Replacement, Suction Motor: step 2, image 1 of 1
    • Remove the five 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  3. Shark Flex DuoClean Suction Motor Replacement: step 3, image 1 of 1
    • Use the iFixit opening tool to remove the top component.
  4. Shark Flex DuoClean Suction Motor Replacement: step 4, image 1 of 1
    • Remove the two 15mm screws by twisting counterclockwise using the T10 Torx screwdriver.
  5. Shark Flex DuoClean Suction Motor Replacement: step 5, image 1 of 1
    • Remove the two 15 mm screws by twisting counterclockwise with a T10 Torx screwdriver.
  6. Shark Flex DuoClean Suction Motor Replacement: step 6, image 1 of 1
    • Remove the two 15 mm screws holding the motor cover by twisting counterclockwise with a T10 Torx screwdriver.
  7. Shark Flex DuoClean Suction Motor Replacement: step 7, image 1 of 1
    • Cut the zip ties holding the motor using the wire cutter.
  8. Shark Flex DuoClean Suction Motor Replacement: step 8, image 1 of 1
    • Cut the wires using the wire cutters to completely remove the motor.
    • For reassembly, use the soldering guide in the Introduction.
2 other people completed this guide.
Christian Fuller
420 Reputation
3 Guides authored
Cal Poly, Team S17-G5, White Fall 2018 Member of Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Members
14 Guides authored
One Comment
how i need to know how to re connect the wires on replacing a new motor, my model is similar HV321.
andrea - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 3,500
