Shark Clean Sense HP102PET Filter Replacement
    1. Shark Clean Sense HP102PET Filter Replacement, Filter: step 1, image 1 of 2 Shark Clean Sense HP102PET Filter Replacement, Filter: step 1, image 2 of 2
      • Turn off and unplug the air purifier before beginning
      • Carefully flip the air purifier upside down and twist the bottom cap to the unlocked position.
      • Remove the bottom cap.
      Ask FixBot
    2. Shark Clean Sense HP102PET Filter Replacement: step 2, image 1 of 1
      • Pull out the old filter using the removal tabs and discard it.
      • Remove all packaging and wrapping from the new filter.
      Ask FixBot
    3. Shark Clean Sense HP102PET Filter Replacement: step 3, image 1 of 1
      • Insert the new filter and replace the filter door. Twist the filter door until it clicks into place.
      • Carefully return the air purifier to the upright position, plug it back in, and turn on the power. Calibration will begin.
      Ask FixBot
    4. Shark Clean Sense HP102PET Filter Replacement: step 4, image 1 of 1
      • After installing a new filter, press and hold the Filter Life button on the top control panel for 3 seconds to reset the filter life percentage. The unit will beep when the filter life is reset to 100%.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 121
All Time: 898
