Sewing a small Hole for a Seamless Fix
Views: 1.4K
View statistics:
Past 24 Hours:
8
Past 7 Days:
83
Past 30 Days:
317
All Time:
1,424
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Having a small hole in your sweater is something that happens to everybody. Whether it’s been caught on something or accidentally torn, sewing it back up will make it look as good as new without having to replace it!
    1. Sewing a small Hole for a Seamless Fix, Sewing a small Hole for a Seamless Fix: step 1, image 1 of 1
      • Ensure the hole is small enough to be easily repaired with sewing.
      Ask FixBot
    2. Sewing a small Hole for a Seamless Fix: step 2, image 1 of 2 Sewing a small Hole for a Seamless Fix: step 2, image 2 of 2
      • Thread the needle with a length of thread doubling it over at the end to secure it.
      • At a good length (depending on the size of the hole), cut off the excess and tie a knot at the end of the thread.
      Ask FixBot
    3. Sewing a small Hole for a Seamless Fix: step 3, image 1 of 1
      • Position the sweater with the hole facing up on a flat surface. Make sure your sweater is inside out.
      • This will make the stitches not as visible.
      Ask FixBot
    4. Sewing a small Hole for a Seamless Fix: step 4, image 1 of 3 Sewing a small Hole for a Seamless Fix: step 4, image 2 of 3 Sewing a small Hole for a Seamless Fix: step 4, image 3 of 3
      • Insert the needle into the fabric slightly above the hole, pulling it through the backside of the sweater, and repeat this process along the edges of the hole to create a series of stitches.
      Ask FixBot
    5. Sewing a small Hole for a Seamless Fix: step 5, image 1 of 1
      • Continue stitching back and forth across the hole in a zig-zag pattern until it is completely closed, ensuring stitches are tight and secure.
      Ask FixBot
    6. Sewing a small Hole for a Seamless Fix: step 6, image 1 of 2 Sewing a small Hole for a Seamless Fix: step 6, image 2 of 2
      • Tie off the thread by creating a small knot at the end of the stitching and trimming any excess thread with scissors.
      Ask FixBot
    7. Sewing a small Hole for a Seamless Fix: step 7, image 1 of 1
      • Reverse your sweater outside in. Tug at the area slightly to ensure the stitches hold and the fabric remains intact.
      Ask FixBot
Finish Line
Kendra Tejada
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 83
Past 30 Days: 317
All Time: 1,424
