Sew a Button
  1. Sew a Button, Button: step 1, image 1 of 1
    • Locate the area where the button has gone missing.
  2. Sew a Button: step 2, image 1 of 2 Sew a Button: step 2, image 2 of 2
    • Overlap the buttonhole with where the button should be. Going through the buttonhole, mark the fabric below with tailor's chalk.
  3. Sew a Button: step 3, image 1 of 2 Sew a Button: step 3, image 2 of 2
    • Get a length of thread—about an arms-length should be more than enough.
    • Thread a needle.
  4. Sew a Button: step 4, image 1 of 3 Sew a Button: step 4, image 2 of 3 Sew a Button: step 4, image 3 of 3
    • Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle.
    • Tie the loose ends of the thread together.
  5. Sew a Button: step 5, image 1 of 2 Sew a Button: step 5, image 2 of 2
    • Tie a second regular knot over the first one to make it bigger. You don't want the thread slipping right through the grain of the fabric.
  6. Sew a Button: step 6, image 1 of 3 Sew a Button: step 6, image 2 of 3 Sew a Button: step 6, image 3 of 3
    • Poke the needle up through the chalk mark from the underside of the fabric.
    • Pull the thread taut, until the knot catches the backside of the fabric.
  7. Sew a Button: step 7, image 1 of 2 Sew a Button: step 7, image 2 of 2
    • Thread the needle through one hole of the button. You can pick any hole to start with.
    • Let the button drop all the way down onto the fabric.
  8. Sew a Button: step 8, image 1 of 3 Sew a Button: step 8, image 2 of 3 Sew a Button: step 8, image 3 of 3
    • Push the needle through the buttonhole directly opposite the one you have already threaded.
    • Be sure to go through only the button, not the fabric.
  9. Sew a Button: step 9, image 1 of 3 Sew a Button: step 9, image 2 of 3 Sew a Button: step 9, image 3 of 3
    • Push the needle back through the fabric directly next to where you initially pushed the needle up.
    • Pull the thread taut, until the button lays flat on the fabric.
  10. Sew a Button: step 10, image 1 of 3 Sew a Button: step 10, image 2 of 3 Sew a Button: step 10, image 3 of 3
    • Push the needle back up through the backside of the fabric, directly next to the original knot
    • Work the needle up through one of the two remaining holes without thread .
    • Pull the thread taut.
  11. Sew a Button: step 11, image 1 of 3 Sew a Button: step 11, image 2 of 3 Sew a Button: step 11, image 3 of 3
    • Go back through the last remaining empty hole on the button.
    • Go back down through the fabric, as close as possible to the other two threads.
  12. Sew a Button: step 12, image 1 of 3 Sew a Button: step 12, image 2 of 3 Sew a Button: step 12, image 3 of 3
    • Drive the needle back up through the underside of the fabric and into the first hole that you threaded.
  13. Sew a Button: step 13, image 1 of 2 Sew a Button: step 13, image 2 of 2
    • Go back down through the second hole, directly across from the hole you just came up through.
    • Pull taut.
  14. Sew a Button: step 14, image 1 of 3 Sew a Button: step 14, image 2 of 3 Sew a Button: step 14, image 3 of 3
    • Push the needle up through the third hole again.
    • Pull it taut.
    • Push the needle down through the fourth hole and pull it taut.
    • Repeat steps 12-14 of this guide one more time, then proceed.
  15. Sew a Button: step 15, image 1 of 3 Sew a Button: step 15, image 2 of 3 Sew a Button: step 15, image 3 of 3
    • You have sewn in the button. Now you need a knot to keep the button in place.
    • Push the needle through the loops of thread on the underside of the fabric. Be careful not to catch the fabric.
  16. Sew a Button: step 16, image 1 of 2 Sew a Button: step 16, image 2 of 2
    • Leave some slack in the thread and draw the needle through the loop created by the slack.
    • Pull the thread taut, forming a knot.
    • Repeat steps 15 and 16 one more time to add a second knot.
  17. Sew a Button: step 17, image 1 of 2 Sew a Button: step 17, image 2 of 2
    • Clip the excess thread off.
    • Check your button for stability.
Brittany McCrigler
89,020 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,299 Guides authored
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 144
All Time: 16,439
