Sew a Button
Views: 27K
View statistics:
Past 24 Hours:
29
Past 7 Days:
153
Past 30 Days:
764
All Time:
26,650
Comments: 10
5 comments on steps, 5 guide comments.
Go to guide comments
Completed: 64
64 people have marked this guide "completed." Will you be next?
Favorites: 79
79 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Sew a Button
Introduction
Go to step 1 ↓
Replacing a button is one of the most common clothing repairs. Fortunately, it's also one of the easiest. This guide will show you how to reattach a standard four-hole button with a needle and thread. In this guide we're using contrasting thread for visibility, but when it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 3 or under. Instead, we recommend return of the product for professional repair services.
Return to the Patagonia Care & Repair homepage.
    1. Sew a Button, Sew a Button: step 1, image 1 of 1
      • Locate the area where the button has gone missing.
      Ask FixBot
    2. Sew a Button: step 2, image 1 of 2 Sew a Button: step 2, image 2 of 2
      • Overlap the buttonhole with where the button should be. Going through the buttonhole, mark the fabric below with tailor's chalk.
      Ask FixBot
    3. Sew a Button: step 3, image 1 of 2 Sew a Button: step 3, image 2 of 2
      • Get a length of thread—about an arms-length should be more than enough.
      • Thread a needle.
      Ask FixBot
    4. Sew a Button: step 4, image 1 of 3 Sew a Button: step 4, image 2 of 3 Sew a Button: step 4, image 3 of 3
      • Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle.
      • Tie the loose ends of the thread together.
      Ask FixBot
    5. Sew a Button: step 5, image 1 of 2 Sew a Button: step 5, image 2 of 2
      • Tie a second regular knot over the first one to make it bigger. You don't want the thread slipping right through the grain of the fabric.
      Ask FixBot
    6. Sew a Button: step 6, image 1 of 3 Sew a Button: step 6, image 2 of 3 Sew a Button: step 6, image 3 of 3
      • Poke the needle up through the chalk mark from the underside of the fabric.
      • Pull the thread taut, until the knot catches the backside of the fabric.
      Ask FixBot
    7. Sew a Button: step 7, image 1 of 2 Sew a Button: step 7, image 2 of 2
      • Thread the needle through one hole of the button. You can pick any hole to start with.
      • Let the button drop all the way down onto the fabric.
      Ask FixBot
    8. Sew a Button: step 8, image 1 of 3 Sew a Button: step 8, image 2 of 3 Sew a Button: step 8, image 3 of 3
      • Push the needle through the buttonhole directly opposite the one you have already threaded.
      • Be sure to go through only the button, not the fabric.
      Ask FixBot
    9. Sew a Button: step 9, image 1 of 3 Sew a Button: step 9, image 2 of 3 Sew a Button: step 9, image 3 of 3
      • Push the needle back through the fabric directly next to where you initially pushed the needle up.
      • Pull the thread taut, until the button lays flat on the fabric.
      Ask FixBot
    10. Sew a Button: step 10, image 1 of 3 Sew a Button: step 10, image 2 of 3 Sew a Button: step 10, image 3 of 3
      • Push the needle back up through the backside of the fabric, directly next to the original knot
      • Work the needle up through one of the two remaining holes without thread.
      • Pull the thread taut.
      Ask FixBot
    11. Sew a Button: step 11, image 1 of 3 Sew a Button: step 11, image 2 of 3 Sew a Button: step 11, image 3 of 3
      • Go back through the last remaining empty hole on the button.
      • Go back down through the fabric, as close as possible to the other two threads.
      Ask FixBot
    12. Sew a Button: step 12, image 1 of 3 Sew a Button: step 12, image 2 of 3 Sew a Button: step 12, image 3 of 3
      • Drive the needle back up through the underside of the fabric and into the first hole that you threaded.
      Ask FixBot
    13. Sew a Button: step 13, image 1 of 2 Sew a Button: step 13, image 2 of 2
      • Go back down through the second hole, directly across from the hole you just came up through.
      • Pull taut.
      Ask FixBot
    14. Sew a Button: step 14, image 1 of 3 Sew a Button: step 14, image 2 of 3 Sew a Button: step 14, image 3 of 3
      • Push the needle up through the third hole again.
      • Pull it taut.
      • Push the needle down through the fourth hole and pull it taut.
      • Repeat steps 12-14 of this guide one more time, then proceed.
      Ask FixBot
    15. Sew a Button: step 15, image 1 of 3 Sew a Button: step 15, image 2 of 3 Sew a Button: step 15, image 3 of 3
      • You have sewn in the button. Now you need a knot to keep the button in place.
      • Push the needle through the loops of thread on the underside of the fabric. Be careful not to catch the fabric.
      Ask FixBot
    16. Sew a Button: step 16, image 1 of 2 Sew a Button: step 16, image 2 of 2
      • Leave some slack in the thread and draw the needle through the loop created by the slack.
      • Pull the thread taut, forming a knot.
      • Repeat steps 15 and 16 one more time to add a second knot.
      Ask FixBot
    17. Sew a Button: step 17, image 1 of 2 Sew a Button: step 17, image 2 of 2
      • Clip the excess thread off.
      • Check your button for stability.
      Ask FixBot
Finish Line
64 other people completed this guide.
Brittany McCrigler
91,148 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
120 Members
72,955 Guides authored
5 Guide Comments
What helps after the last step 14 is to wrap the thread around and around a few times underneath the button itself (binding all the threads together) and making one last pass through the cloth before the final knot. This makes the repair much more durable.
mccreerydennis - Reply Share
The wrapping below the button is not only more durable, but is actually frequently used when replacing buttons on blazers, sport coats, and the like as a protection from friction as the garment moves and shifts while being worn.
Matt - Reply Share
Wrapping the threads underneath the button to create a shank is useful for coat buttons where the fabric is thick and you don’t want the fabric to pucker. As noted, it adds durability to the button attachment. On a shirt collar, as seen here, it would create too much bulk where you need the button to lie quite flat, so this method is quite sufficient.
Jonathan Wells - Reply Share
Thanks Jonathan. Great insight.
Louie Leung - Reply Share
Parfait, mon pantalon est comme neuf :)
Brendan - Reply Share
Past 24 Hours: 29
Past 7 Days: 153
Past 30 Days: 764
All Time: 26,650
