Up to 20% off select tools
Separating Main Board
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
78
All Time:
1,440
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This Prerequisite-Only guide shows how to remove the front board from the 8BitDo SN30 Pro+
    1. Separating Main Board, Remove Battery: step 1, image 1 of 3 Separating Main Board, Remove Battery: step 1, image 2 of 3 Separating Main Board, Remove Battery: step 1, image 3 of 3
      • Place the controller face down.
      • Remove the battery cover.
      • Remove rechargeable battery or AA batteries.
      Ask FixBot
    2. Separating Main Board, Remove Trigger Buttons: step 2, image 1 of 2 Separating Main Board, Remove Trigger Buttons: step 2, image 2 of 2
      • Remove L2 and R2 trigger buttons by pushing them away from the grips.
      Ask FixBot
    3. Separating Main Board, Remove Screws: step 3, image 1 of 2 Separating Main Board, Remove Screws: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use Tweezers to uncover two screws under the label in the battery compartment.
      • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
      Ask FixBot
    4. Separating Main Board, Unclip Covers: step 4, image 1 of 3 Separating Main Board, Unclip Covers: step 4, image 2 of 3 Separating Main Board, Unclip Covers: step 4, image 3 of 3
      • At the end of each grip, pry apart the covers.
      • Use fingernail or opening pick to undo the two top clips.
      • One clip next to L button.
      • One clip next to R button
      • Undo the final clip between the joysticks.
      Ask FixBot
    5. Separating Main Board, Separate Covers: step 5, image 1 of 1
      • Carefully move the rear cover away and from the front cover. Place it to the left.
      • Do not completely separate. The two halves are still attached via a white ribbon cable.
      Ask FixBot
    1. Separating Main Board, Remove Ribbon Cable: step 6, image 1 of 3 Separating Main Board, Remove Ribbon Cable: step 6, image 2 of 3 Separating Main Board, Remove Ribbon Cable: step 6, image 3 of 3
      • Unlock the ribbon cable by push open the black plastic tab.
      • The tab will slide about 1.5mm
      • Pull the ribbon cable out of the connector in the direction of the cable.
      Ask FixBot
    2. Separating Main Board, Remove Screws: step 7, image 1 of 3 Separating Main Board, Remove Screws: step 7, image 2 of 3 Separating Main Board, Remove Screws: step 7, image 3 of 3
      • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
      • Six 10.1mm screws
      • One 5.8mm screws
      Ask FixBot
    3. Separating Main Board, Separate Main Board: step 8, image 1 of 3 Separating Main Board, Separate Main Board: step 8, image 2 of 3 Separating Main Board, Separate Main Board: step 8, image 3 of 3
      • Slide the R buttons up and off its peg.
      • Slide the L button up and off its peg.
      • Remove the main board by rotating it towards the USB-C port. Then lift it out.
      Ask FixBot
Author
with
Brian W
1,800 Reputation
8 Guides authored
1 Guide Comment
if you need a replacement ribbon the specs are
length: 70mm
pitch: 0.5mm
pins: 20
forward side pinning (that means the contacts are on the same side)
some listings add the total width, thats 20.5mm
Max R. - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 78
All Time: 1,440
