Shop the Holiday Gift Guide
Sennheiser Momentum Wireless M2 AEBT Earmuff Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
Past 7 Days:
41
Past 30 Days:
156
All Time:
2,220
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The earmuffs may need to be replaced if they are damaged over time or due to excessive exposure to water. The process to replace the earmuffs is quite easy and can be done in under a minute. You can contact Sennheiser for additional spare parts such as the earmuff. You will not need any other tools for this replacement process.
Parts
Tools
    1. Sennheiser Momentum Wireless M2 AEBT Earmuff Replacement, Earmuff: step 1, image 1 of 1
      • Grab the earmuff with one hand and hold the headphones with the other.
      Ask FixBot
    2. Sennheiser Momentum Wireless M2 AEBT Earmuff Replacement: step 2, image 1 of 1
      • Pull the earmuff near the top until the seam starts to pull from the split in the headphone case. Continue until the earmuff fully separates from the headphones as shown.
      • NOTE: When re-attaching to the headphone the last few inches have to be stretched, use a blunt opening tool or cotton bud to hook under the membrane and pull into position as you push from the inside with your fingers.
      Ask FixBot
Be careful to not damage the membrane when stretching the last part over the ear cup, take your time.
Author
with
welsayed
326 Reputation
3 Guides authored
2 Guide Comments
Putting the muffs back on is very fiddly as you need to feed the edges into a narrow slit that goes right round.
Henry Collingridge - Reply Share
Sennheiser should be ashamed for the design of the earmuffs. So many vendor videos showing how EASY it is to slip on the replacements into the little ridge. BS X 1000!!! It will be a VERY cold day in Hades before I’ll seriously consider buying another Sennheiser product.
Jennifer Willis-Opalenik - Reply Share
Past 24 Hours: 1
Past 7 Days: 41
Past 30 Days: 156
All Time: 2,220
