Shop the Holiday Gift Guide
Sennheiser Momentum Wireless M2 AEBT Battery Replacement
Views: 9.4K
View statistics:
Past 24 Hours:
15
Past 7 Days:
64
Past 30 Days:
328
All Time:
9,421
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The headphones not charging or needing to be charged constantly can be due to a faulty or worn out battery. This guide will help guide users on how to remove and replace the battery. The process is relatively easy difficult, it requires the use of the standard #0 Philips screwdriver and a new battery which can be ordered online.
Tools
    1. Sennheiser Momentum Wireless M2 AEBT Battery Replacement, Earmuff: step 1, image 1 of 1
      • Grab the earmuff with one hand and hold the headphones with the other.
      Ask FixBot
    2. Sennheiser Momentum Wireless M2 AEBT Battery Replacement: step 2, image 1 of 1
      • Pull the earmuff near the top until the seam starts to pull from the split in the headphone case. Continue until the earmuff fully separates from the headphones as shown.
      • NOTE: When re-attaching to the headphone the last few inches have to be stretched, use a blunt opening tool or cotton bud to hook under the membrane and pull into position as you push from the inside with your fingers.
      Ask FixBot
    1. Sennheiser Momentum Wireless M2 AEBT Battery Replacement, Battery: step 3, image 1 of 3 Sennheiser Momentum Wireless M2 AEBT Battery Replacement, Battery: step 3, image 2 of 3 Sennheiser Momentum Wireless M2 AEBT Battery Replacement, Battery: step 3, image 3 of 3
      • Using a sharp knife, carefully remove the clear plastic stickers covering the screw holes, and save them for later. Use the #0 Philips screwdriver to unscrew the four 8mm long screws.
      • Grab the cover and carefully pull off to view inside of headphone.
      • NOTE! There is a small wire from the mainboard to the outer shell which remains attached to the headband. This is the NFC pairing wire and if broken the NFC functionality will be lost.
      Ask FixBot
    2. Sennheiser Momentum Wireless M2 AEBT Battery Replacement: step 4, image 1 of 2 Sennheiser Momentum Wireless M2 AEBT Battery Replacement: step 4, image 2 of 2
      • Take note of the path the wires are place into from the battery to the terminal on the main board.
      • Use a spudger or finger nails to carefully pry out the battery connector (and wires) from the terminal on the main board. Once removed this will disconnect the wires connected to battery.
      • NOTE! There is a very fine wire which crosses over the battery and you must be careful to not break this wire, so the battery has to be lifted out from the top.
      • Working from the opposite end of the battery wires, carefully pry the battery off from its light adhesive.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4 other people completed this guide.
Author
with
Robert Wahl
271 Reputation
1 Guide authored
1 Guide Comment
Danke für die Anleitung. Was für ein Akkutyp ist das denn bitte?
Frasa - Reply Share
Past 24 Hours: 15
Past 7 Days: 64
Past 30 Days: 328
All Time: 9,421
