Sega Master System II Motherboard Replacement
  1. Sega Master System II Motherboard Replacement, Outer Case: step 1, image 1 of 1
    • Flip the console on it's back and unscrew the 5 screws marked on this photo.
  2. Sega Master System II Motherboard Replacement: step 2, image 1 of 1
    • Once you've unscrewed those 5 screws, flip the console upright again.
  3. Sega Master System II Motherboard Replacement: step 3, image 1 of 2 Sega Master System II Motherboard Replacement: step 3, image 2 of 2
    • Once the console is upright, first gently pull the rear of the top up.
    • After the top is at an angle, gently remove it by pulling upwards.
    • Note: Be very careful! The top has 2 tabs connecting it with the bottom half, those are in the vincinity of the 2 controller ports! (marked yellow)
  4. Sega Master System II Motherboard Replacement: step 4, image 1 of 1
    • Once the 2 halves are separated, it should look something like this.
  5. Sega Master System II Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Next step is the removal of the RF shield
    • There are 7 screws in total, please unscrew those.
    • The blue marked screw is shorten than the other 6 screws, this screw has to be put back in the exact same location during reassembly.
    • Note: Tab marked in yellow!
  6. Sega Master System II Motherboard Replacement: step 6, image 1 of 1
    • Carefully lift the RF shield up, left side first.
    • See note previous step.
  7. Sega Master System II Motherboard Replacement: step 7, image 1 of 2 Sega Master System II Motherboard Replacement: step 7, image 2 of 2
    • Now we have a complete view of the motherboard, thus coming to the last step.
    • For this step you only need to remove 3 remaining screws.
    • 2 screws on the connector.
    • There's 1 shorter screw as previously with the RF shield. This small screw keeps the voltage regulator in place.
  8. Sega Master System II Motherboard Replacement: step 8, image 1 of 1
    • When you've disassembled everything, it should look like this.
    • Once you've got the replacement board, just follow this guide in reverse order,
Arjan Kuiper
290 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 57
All Time: 4,068
