Introduction
How to repair the speakers of a Sega Game Gear.
Video Overview
Remove the following screws:
Six Phillips screws
One 4.5 mm Gamebit screw
The screw hole in the bottom center is for the PowerBack. Also there are not 7 screws there are only 6
Carefully unplug the 2 white-tipped connectors on the top cover.
Il faut aussi débrancher le connecteur du haut parleur (2 broches, en haut à droite).
There is a third cable on the right side of the top half in this picture which is the speaker. Unplug that too.
Unscrew the 8 Phillips screws from the logic board.
There are 2 additional screws to remove from the motherboard to the left and right of the cartridge port's shiny metal shield's screws on my Sega Game Gear with the RED GREEN and BLUE colors on the front.
The plastic at these three locations is melted to the plastic. Pry off with caution.
Recommendations for the prying off process? It looks like a soldering iron was taken to the points to loosen the plastic but I'm not sure
I found that poking around the orange/redish posts with a hobby knife worked really well. Poke a small hole where the black plastic meets the red plastic and continue doing this around the post. Once you have done that it might help to go around the post a second time pressing more firmly as to push the knife just a little further. Use your finger or plastic prying tool to pry up each side. I wouldn't recommend just taking a prying tool to each post without breaking the connection between the posts and the retaining plate as you will potentially break the plate that holds the speaker in place. This is very easy to do but it is time consuming if you're concerned with keeping everything in as close to "new" condition as possible.
2 other people completed this guide.
