Sega Dreamcast Top Cover Replacement
  1. Sega Dreamcast Top Cover Replacement, Expansion Bay: step 1, image 1 of 2 Sega Dreamcast Top Cover Replacement, Expansion Bay: step 1, image 2 of 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Top Cover Replacement: step 2, image 1 of 3 Sega Dreamcast Top Cover Replacement: step 2, image 2 of 3 Sega Dreamcast Top Cover Replacement: step 2, image 3 of 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Top Cover Replacement, Top Cover: step 3, image 1 of 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • The fourth screw is hidden under the expansion bay if it has not already been removed.
  4. Sega Dreamcast Top Cover Replacement: step 4, image 1 of 1
    • Be careful that the internal components do not topple out.
    • Flip the console topside up.
    • Remove the top cover of the chassis by gently lifting the upper portion of the console.
wkwong
533 Reputation
5 Guides authored
Cal Poly, Team 5-1, Regan Fall 2009 Member of Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Members
21 Guides authored
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 78
All Time: 11,911
