Sega Dreamcast Fan Replacement
  1. Sega Dreamcast Fan Replacement, Expansion Bay: step 1, image 1 of 2 Sega Dreamcast Fan Replacement, Expansion Bay: step 1, image 2 of 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Fan Replacement: step 2, image 1 of 3 Sega Dreamcast Fan Replacement: step 2, image 2 of 3 Sega Dreamcast Fan Replacement: step 2, image 3 of 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Fan Replacement, Top Cover: step 3, image 1 of 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Fan Replacement: step 4, image 1 of 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
  5. Sega Dreamcast Fan Replacement, Fan: step 5, image 1 of 1
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
  6. Sega Dreamcast Fan Replacement: step 6, image 1 of 1
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
  7. Sega Dreamcast Fan Replacement: step 7, image 1 of 2 Sega Dreamcast Fan Replacement: step 7, image 2 of 2
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
  8. Sega Dreamcast Fan Replacement, Fan: step 8, image 1 of 2 Sega Dreamcast Fan Replacement, Fan: step 8, image 2 of 2
    • Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
    • Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
Thorr686
472 Reputation
2 Guides authored
Cal Poly, Team 5-1, Regan Fall 2009 Member of Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Members
21 Guides authored
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 34
All Time: 18,782
