Sega CD Genesis Connector Replacement
  1. Sega CD Genesis Connector Replacement, Sega CD Plastic Housing Removal: step 1, image 1 of 2 Sega CD Genesis Connector Replacement, Sega CD Plastic Housing Removal: step 1, image 2 of 2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD Genesis Connector Replacement: step 2, image 1 of 1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD Genesis Connector Replacement: step 3, image 1 of 1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD Genesis Connector Replacement: step 4, image 1 of 1
    • Lift from the left side to remove the top of the case.
  5. Sega CD Genesis Connector Replacement: step 5, image 1 of 1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD Genesis Connector Replacement: step 6, image 1 of 1
    • Lift the top of the case to remove the cover.
  7. Sega CD Genesis Connector Replacement: step 7, image 1 of 1
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD Genesis Connector Replacement, Genesis Connector: step 8, image 1 of 2 Sega CD Genesis Connector Replacement, Genesis Connector: step 8, image 2 of 2
    • Using a #00 Philips screwdriver remove the two screws that attach the Genesis adapter to the console.
    • Disconnect the adapter from the console by carefully pulling the adapter out.
  9. Sega CD Genesis Connector Replacement: step 9, image 1 of 1
    • Remove the four screws from the metal plate as shown using a #00 Philips screwdriver.
    • The four half inch bronze screws are indicated by the yellow marking circles.
  10. Sega CD Genesis Connector Replacement: step 10, image 1 of 2 Sega CD Genesis Connector Replacement: step 10, image 2 of 2
    • Carefully remove the metal cover from connector as shown by sliding the cover up and out.
  11. Sega CD Genesis Connector Replacement: step 11, image 1 of 2 Sega CD Genesis Connector Replacement: step 11, image 2 of 2
    • Remove the connector from the housing.
Ryan Kotzebue
271 Reputation
4 Guides authored
Cal Poly, Team 5-14, Maness Fall 2010 Member of Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 5,882
