Screen Replacement
Views: 4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
31
Past 30 Days:
175
All Time:
3,970
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Screen Replacement
Introduction
Go to step 1 ↓
This guide will walk through the process of removing the screen. This guide has a large number of steps due to the need to remove the motherboard from the device before the screen will be accessible. Double check the tools needed for this guide as soldering is necessary for this disassembly.
Tools
    1. Screen Replacement, Back Cover: step 1, image 1 of 3 Screen Replacement, Back Cover: step 1, image 2 of 3 Screen Replacement, Back Cover: step 1, image 3 of 3
      • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
      • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
      • Avoid prying on the buttons, as they are easily damaged.
      Ask FixBot
    2. Screen Replacement: step 2, image 1 of 1
      • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
      Ask FixBot
    1. Screen Replacement, Battery: step 3, image 1 of 1
      • Remove masking tape from the battery.
      Ask FixBot
    2. Screen Replacement: step 4, image 1 of 3 Screen Replacement: step 4, image 2 of 3 Screen Replacement: step 4, image 3 of 3
      • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
      • Handle the battery with care to avoid damaging it.
      Ask FixBot
    3. Screen Replacement: step 5, image 1 of 3 Screen Replacement: step 5, image 2 of 3 Screen Replacement: step 5, image 3 of 3
      • De-solder the three contact points and remove the battery.
      • See the following guide for instructions on how to solder. How To Solder and Desolder Connections
      • Use caution when operating the soldering iron.
      Ask FixBot
    1. Screen Replacement, Motherboard: step 6, image 1 of 3 Screen Replacement, Motherboard: step 6, image 2 of 3 Screen Replacement, Motherboard: step 6, image 3 of 3
      • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
      • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
      Ask FixBot
    2. Screen Replacement: step 7, image 1 of 1
      • Use the nut driver and J00 bit to remove the three 4 mm screws.
      Ask FixBot
    3. Screen Replacement: step 8, image 1 of 3 Screen Replacement: step 8, image 2 of 3 Screen Replacement: step 8, image 3 of 3
      • Peel back metal tape that is hiding the auxiliary port wires.
      • Remove tape that is holding the speaker wires in place.
      • Lift up on the motherboard to release it from the tablet.
      Ask FixBot
    1. Screen Replacement, Screen: step 9, image 1 of 1
      • Use the nut driver and the J0 bit to unscrew the four 4 mm screws
      Ask FixBot
    2. Screen Replacement: step 10, image 1 of 2 Screen Replacement: step 10, image 2 of 2
      • If your are replacing a broken screen be careful when handling broken glass.
      • Remove the screen from the front cover of the device. At this point there should be no other component holding the screen down.
      Ask FixBot
Walker Karstens
364 Reputation
3 Guides authored
Baylor, Team 4-1, Williams Fall 2016 Member of Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 175
All Time: 3,970
