Dexter Corded Jigsaw 750W Charcoal Replacement
  1. Dexter Corded Jigsaw 750W Charcoal Replacement, Débranchez: step 1, image 1 of 1
    • Before you start, remember to disconnect the power plug.
  2. Dexter Corded Jigsaw 750W Charcoal Replacement: step 2, image 1 of 1
    • Remove the vacuum adapter from the back of the unit.
  3. Dexter Corded Jigsaw 750W Charcoal Replacement: step 3, image 1 of 2 Dexter Corded Jigsaw 750W Charcoal Replacement: step 3, image 2 of 2
    • Using a screwdriver unscrew and open the unit.
    • Unlock the tray by lifting the lever.
    • Lever the coal out of its housing.
    • Press lightly on the paw with a point to make it come out.
    • Remove the coal by pressing on it.
    • Lift the small tab from the inside by pressing on it, it should stick out slightly.
  4. Dexter Corded Jigsaw 750W Charcoal Replacement: step 7, image 1 of 3 Dexter Corded Jigsaw 750W Charcoal Replacement: step 7, image 2 of 3 Dexter Corded Jigsaw 750W Charcoal Replacement: step 7, image 3 of 3
    • Put the new coal in the coal holder.
    • Pull on the charcoal to make it stick out.
    • Clip the tip into the charcoal holder and check that it fits properly.
    • Check the mechanism, so that everything slides perfectly.
  5. Dexter Corded Jigsaw 750W Charcoal Replacement: step 10, image 1 of 2 Dexter Corded Jigsaw 750W Charcoal Replacement: step 10, image 2 of 2
    • Compress the carbon holder and put it back in its housing.
    • The coal holder must be in the right direction, the small line is at the end.
  6. Dexter Corded Jigsaw 750W Charcoal Replacement: step 11, image 1 of 1
    • Close and screw the unit back on.
Finish Line
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,581 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
36 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 620
