Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement
  1. Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement, Unplug: step 1, image 1 of 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 2, image 1 of 2 Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 2, image 2 of 2
    • Remove the dust extraction nozzle, blade and edge guide.
    • Refer to the instructions for the device to remove them.
  3. Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 3, image 1 of 1
    • Open wide to free up space for a better work area.
    • Using a large pat screwdriver, remove the small pin.
    • Then remove the black rod.
    • And finally unscrew the nut.
  4. Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 7, image 1 of 1
    • Here is the order of the parts to remove.
  5. Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 8, image 1 of 2 Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 8, image 2 of 2
    • Then we replace the height adjustment.
  6. Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 9, image 1 of 2 Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 9, image 2 of 2
    • Finally put each piece back in order.
    • To tighten, simply replace the tray at the bottom and hand tighten the nut.
    • With the lever, take the nut and put it in the locked position without effort
    • It should be tight but not touching the board.
  7. Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 10, image 1 of 2 Dexter Corded Circular Saw - 1300CIS2-185.5 Height Adjustment Replacement: step 10, image 2 of 2
    • Replace the blade, edge guide, and extraction bit on the saw.
to reassemble perform the steps in reverse order.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
16,581 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
36 Members
239 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,212
