Introduction
This guide will help you replace the keypad on your Sanyo-PM 8200 flip phone. In order to replace it, you will need to remove the back casing from the device and lift the motherboard.
Push and hold the button on the back toward the direction of the arrow to unlock the battery.
Lift and remove the battery from the back of the phone.
Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
This detail is important for other Sanyo flip phones as well. I was swapping motherboards in a pair of SCP-3820s where one had a broken display, and the screws under these neoprene screw covers had me stymied for a while!
Unscrew all four, 5mm Tri-Wing screws.
Tri-wing screws are a reason I hate Sanyo with my entire being. If you haven’t experienced them before, you will need to purchase a specialty screwdriver tip, often called a Y-tip or a tri-wing tip. In my case working on a Sanyo SCP-3820, the 2.5 size worked, but I could have used the 2.0 as well. No other style of screwdriver will work.
Remove the camera and call keys from the side of the phone where the antenna is located.
Remove the Readylink and volume control buttons from the other side of the phone.
One Comment
In almost all flip phones, there’s a flex cable ribbon that connects the motherboard to the display side of the phone. It is permanently attached to the display side and plugs into the motherboard. As there are anywhere from 16 to 50 connections in the cable, I recommend being careful NOT to unplug it…aligning it for plugging it back in properly can be tricky!
