Sanyo dp50747 Plasma TV fuse replacement and power board check
  1. Sanyo dp50747 Plasma TV fuse replacement and power board check, Fuse - Power Board: step 1, image 1 of 1
    • Step 1 - Remove all 42 screws from back cover. Remove top center screw last, it will help to hold the panel in place during removal of other screws.
  2. Sanyo dp50747 Plasma TV fuse replacement and power board check: step 2, image 1 of 1
    • WARNING!!! DO NOT TOUCH ANYTHING INSIDE. Even after disconnected from the power outlet, the capacitors are electrical components capable of storing electrical energy. Some can have the same energy as a defibrillator and could easily stop your heart. WARNED!!!
    • There are 5 fuses total, make sure to remove them from the holder and check for continuity with a multimeter.
    • If all test Ok, you might need to have the Power board replaced.
  3. Sanyo dp50747 Plasma TV fuse replacement and power board check: step 3, image 1 of 1
    • That's the one that I found faulty. Just Remove it with a pair of needle-nose pliers and replace with a new one (ft8ah250vp).
  4. Sanyo dp50747 Plasma TV fuse replacement and power board check: step 4, image 1 of 1
    • TV up and running... and the best part was that it only cost me less than a dollar to get it repaired!!!!
Andre Silveira
1,016 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 67
All Time: 138,858
