Removing Sanyo VPC-X1200 Flash Lens
  1. Removing Sanyo VPC-X1200 Flash Lens, Back Case: step 1, image 1 of 3 Removing Sanyo VPC-X1200 Flash Lens, Back Case: step 1, image 2 of 3 Removing Sanyo VPC-X1200 Flash Lens, Back Case: step 1, image 3 of 3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Removing Sanyo VPC-X1200 Flash Lens: step 2, image 1 of 1
    • Gently lift up the back cover and set aside.
  3. Removing Sanyo VPC-X1200 Flash Lens, LCD Screen: step 3, image 1 of 2 Removing Sanyo VPC-X1200 Flash Lens, LCD Screen: step 3, image 2 of 2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Removing Sanyo VPC-X1200 Flash Lens: step 4, image 1 of 2 Removing Sanyo VPC-X1200 Flash Lens: step 4, image 2 of 2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Removing Sanyo VPC-X1200 Flash Lens, Button Plate: step 5, image 1 of 2 Removing Sanyo VPC-X1200 Flash Lens, Button Plate: step 5, image 2 of 2
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Removing Sanyo VPC-X1200 Flash Lens: step 6, image 1 of 2 Removing Sanyo VPC-X1200 Flash Lens: step 6, image 2 of 2
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
  7. Removing Sanyo VPC-X1200 Flash Lens, Lens Unit: step 7, image 1 of 1
    • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
    • One gate is black and another is white.
  8. Removing Sanyo VPC-X1200 Flash Lens: step 8, image 1 of 2 Removing Sanyo VPC-X1200 Flash Lens: step 8, image 2 of 2
    • Remove the three silver screws.
    • Three 5.5mm screws
  9. Removing Sanyo VPC-X1200 Flash Lens: step 9, image 1 of 1
    • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
  10. Removing Sanyo VPC-X1200 Flash Lens, Flash Lens: step 10, image 1 of 3 Removing Sanyo VPC-X1200 Flash Lens, Flash Lens: step 10, image 2 of 3 Removing Sanyo VPC-X1200 Flash Lens, Flash Lens: step 10, image 3 of 3
    • Remove 4 screws in the hole which contained the lens unit.
    • Four 3.5mm screws
  11. Removing Sanyo VPC-X1200 Flash Lens: step 11, image 1 of 1
    • Remove round silver bezel from the front of the camera.
  12. Removing Sanyo VPC-X1200 Flash Lens: step 12, image 1 of 1
    • Remove the two screws on the bottom of the front cover.
  13. Removing Sanyo VPC-X1200 Flash Lens: step 13, image 1 of 1
    • Remove tripod mount.
  14. Removing Sanyo VPC-X1200 Flash Lens: step 14, image 1 of 1
    • Carefully lift off the front cover plate of the camera.
  15. Removing Sanyo VPC-X1200 Flash Lens: step 15, image 1 of 1
    • Remove the flash lens using the spudger or a finger.
    • It will be attached by a piece of tape, peel the lens off of that piece of tape without removing the tape.
Anthony Giardina
20 Reputation
7 Guides authored
Cal Poly, Team 7-10, Maness Spring 2010 Member of Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Members
14 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 2,123
