Sanyo VPC-X1200 Button Plate Replacement
  1. Sanyo VPC-X1200 Button Plate Replacement, Back Case: step 1, image 1 of 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: step 1, image 2 of 3 Sanyo VPC-X1200 Button Plate Replacement, Back Case: step 1, image 3 of 3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
  2. Sanyo VPC-X1200 Button Plate Replacement: step 2, image 1 of 1
    • Gently lift up the back cover and set aside.
  3. Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: step 3, image 1 of 2 Sanyo VPC-X1200 Button Plate Replacement, LCD Screen: step 3, image 2 of 2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
  4. Sanyo VPC-X1200 Button Plate Replacement: step 4, image 1 of 2 Sanyo VPC-X1200 Button Plate Replacement: step 4, image 2 of 2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
  5. Sanyo VPC-X1200 Button Plate Replacement, Button Plate: step 5, image 1 of 2 Sanyo VPC-X1200 Button Plate Replacement, Button Plate: step 5, image 2 of 2
    • There are five screws of three different sizes which need removal.
    • One 4.5mm screw
    • Four 3.5mm screws, one on the button side
    • One 5.5mm screws
  6. Sanyo VPC-X1200 Button Plate Replacement: step 6, image 1 of 2 Sanyo VPC-X1200 Button Plate Replacement: step 6, image 2 of 2
    • Slowly lift metal tray to the right.
    • Be careful not to bend the screw tabs or rip out the ribbon cable.
    • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
Anthony Giardina
20 Reputation
7 Guides authored
Cal Poly, Team 7-10, Maness Spring 2010 Member of Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Members
14 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 15
All Time: 2,227
