Installing Sanyo Katana Motherboard
  1. Installing Sanyo Katana Motherboard, Battery: step 1, image 1 of 3 Installing Sanyo Katana Motherboard, Battery: step 1, image 2 of 3 Installing Sanyo Katana Motherboard, Battery: step 1, image 3 of 3
    • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
    • While holding down the button, pull cover off with other hand.
  2. Installing Sanyo Katana Motherboard: step 2, image 1 of 3 Installing Sanyo Katana Motherboard: step 2, image 2 of 3 Installing Sanyo Katana Motherboard: step 2, image 3 of 3
    • Use fingers to grip the battery and remove it from the phone.
  3. Installing Sanyo Katana Motherboard, Back Casing: step 3, image 1 of 1
    • Using a spudger, remove the four rubber coverings on the lower back plate.
  4. Installing Sanyo Katana Motherboard: step 4, image 1 of 3 Installing Sanyo Katana Motherboard: step 4, image 2 of 3 Installing Sanyo Katana Motherboard: step 4, image 3 of 3
    • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
  5. Installing Sanyo Katana Motherboard: step 5, image 1 of 3 Installing Sanyo Katana Motherboard: step 5, image 2 of 3 Installing Sanyo Katana Motherboard: step 5, image 3 of 3
    • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
  6. Installing Sanyo Katana Motherboard, Motherboard: step 6, image 1 of 2 Installing Sanyo Katana Motherboard, Motherboard: step 6, image 2 of 2
    • Unscrew the 4.4mm screws at the top of the phone with the Tri-wing Y0 Screwdriver.
  7. Installing Sanyo Katana Motherboard: step 7, image 1 of 3 Installing Sanyo Katana Motherboard: step 7, image 2 of 3 Installing Sanyo Katana Motherboard: step 7, image 3 of 3
    • For the following steps, the phone is shown closed to make manipulating the parts easier.
    • Using a spudger, remove the thin aluminum plate to access the upper motherboard.
    • This will most likely be difficult to pry off and will take a considerable amount of force. Stay clear of the piece to avoid injury when it comes free of the device.
  8. Installing Sanyo Katana Motherboard: step 8, image 1 of 1
    • Use the flat end of the spudger to remove two ribbon cables from the back of the motherboard.
  9. Installing Sanyo Katana Motherboard: step 9, image 1 of 3 Installing Sanyo Katana Motherboard: step 9, image 2 of 3 Installing Sanyo Katana Motherboard: step 9, image 3 of 3
    • Open the phone and firmly hold the phone casing with one hand and push the motherboard out of the case with the other by pushing on the keys.
    • Once the keys are free from the casing, close the phone and pull the motherboard from the back of the phone the remainder of the way with your fingers.
StephenYH
20 Reputation
3 Guides authored
Clemson, Team 12-1, Benson Spring 2013 Member of Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Members
20 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 529
