Installing Sanyo Katana Front Case
  1. Installing Sanyo Katana Front Case, Screen Protector: step 1, image 1 of 2 Installing Sanyo Katana Front Case, Screen Protector: step 1, image 2 of 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Installing Sanyo Katana Front Case: step 2, image 1 of 2 Installing Sanyo Katana Front Case: step 2, image 2 of 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Installing Sanyo Katana Front Case: step 3, image 1 of 2 Installing Sanyo Katana Front Case: step 3, image 2 of 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Installing Sanyo Katana Front Case, Front Case: step 4, image 1 of 3 Installing Sanyo Katana Front Case, Front Case: step 4, image 2 of 3 Installing Sanyo Katana Front Case, Front Case: step 4, image 3 of 3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
StephenYH
20 Reputation
3 Guides authored
Clemson, Team 12-1, Benson Spring 2013 Member of Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Members
20 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 258
