Sansa e260R Scroll Wheel Replacement
  1. Sansa e260R Scroll Wheel Replacement, Rear Case: step 1, image 1 of 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Scroll Wheel Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Scroll Wheel Replacement: step 3, image 1 of 1
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Scroll Wheel Replacement, Battery: step 4, image 1 of 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Scroll Wheel Replacement, Front Panel: step 5, image 1 of 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Scroll Wheel Replacement: step 6, image 1 of 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Scroll Wheel Replacement: step 7, image 1 of 2 Sansa e260R Scroll Wheel Replacement: step 7, image 2 of 2
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Scroll Wheel Replacement, Scroll Wheel: step 8, image 1 of 2 Sansa e260R Scroll Wheel Replacement, Scroll Wheel: step 8, image 2 of 2
    • Gently pry the bottom of the black button to remove it from the device.
  9. Sansa e260R Scroll Wheel Replacement: step 9, image 1 of 2 Sansa e260R Scroll Wheel Replacement: step 9, image 2 of 2
    • There are 4 small metal hooks under the white scrolling mechanism.
    • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
  10. Sansa e260R Scroll Wheel Replacement: step 10, image 1 of 1
    • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
JenniferW
194 Reputation
2 Guides authored
Cal Poly, Team 8-15, Maness Winter 2012 Member of Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 3,251
