Installing Sansa e260R Front Panel
  1. Installing Sansa e260R Front Panel, Rear Case: step 1, image 1 of 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Installing Sansa e260R Front Panel: step 2, image 1 of 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Installing Sansa e260R Front Panel: step 3, image 1 of 1
    • Pull the rear panel off of the Sansa e260R.
  4. Installing Sansa e260R Front Panel, Battery: step 4, image 1 of 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Installing Sansa e260R Front Panel, Front Panel: step 5, image 1 of 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Installing Sansa e260R Front Panel: step 6, image 1 of 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Installing Sansa e260R Front Panel: step 7, image 1 of 2 Installing Sansa e260R Front Panel: step 7, image 2 of 2
    • Pull the front cover away from the rest of the device.
Casey Smith
111 Reputation
3 Guides authored
Cal Poly, Team 8-15, Maness Winter 2012 Member of Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,983
